Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-01-2009, 11:26 AM   #1
89 Sea Ray Pachanga 32
Help me understand counter rotating props?
Fairly new to twin engines. I had a Larson with twin screws that turned opposite of each other. I now have a Sea Ray with twins, but both props are the same. Neither engine runs, so no idea if one is counter or not. If it were, I assume the outdrive would also be counter in order for the prop to work correctly. My question is this - is there such thing as a counter outdrive or is it just cabled backwards? If it is just a cabling change, what about the water pump - it is in the outdrive (Alpha) so wouldn't it be running backwards as well? Reason for all the questions is that I want to get a counter prop and make it like the Larson - the wake it left was awesome for skiing and I want both engines to turn "normal" as counter turn parts are more expensive and harder to find... It makes sense to me that for a counter rotating engine, you would only need to change the cam, starter and oil pump Maybe the dist gear is different as well. Then reverse the firing order or something like that... Just guessing...
Thanks!
Dustin
spunner is offline   Reply With Quote
Old 10-01-2009, 12:36 PM   #2
Fuelin Around
FuelinAround's Avatar
Sonic 31SS
The drives are the same But wired backwards... Also it's the props that are angled backwards.... You prolly want them rotating inwards....hope this helps... Most people agree u should also swap the drives occassionally to make the gears wear more evenly. Kind of the same idea as rotating tires. Make sure and swap the props when you do this.
FuelinAround is offline   Reply With Quote
Sponsored Links
Old 10-01-2009, 12:47 PM   #3
Thanks for the reply - so you are saying with my Alpha drives it doesn't matter the direction they spin, the pickup will work either way? All I have to do is find a counter prop and change the linkage? That would be too easy!
Old 10-01-2009, 12:52 PM   #4
32 Active Thunder
Alpha's have standard(RH) and counter rotating(LH) drives. They can't be run the opposite direction. The impeller is in the drive in an Alpha.
Bravo drives can be run either way.
Griff is offline   Reply With Quote
Old 10-01-2009, 01:31 PM   #5
crud. Now I wonder if the motor was counter as well as the outdrive (which would make absolutely no sense) but a marine engine guy told me it was common. Is there a way to tell by looking at the unit or do I have to find a number on it somewhere to tell if it is RH or LH?
Old 10-01-2009, 01:44 PM   #6
Fuelin Around
Sonic 31SS
And I got educated on something!.... Wasn't aware of that but then again I have only had bravos
Old 10-01-2009, 03:02 PM   #7
Go Big or Go Home
stageharbor's Avatar
78 cig 28 ss, 89 donzi 33zf
as far as i know all stern drive engines are std rotation. i think they started making counter rotation alphas in the late eighties. so if your boat is older you may have two right hand units. usually the end of the prop shaft will be stamped with L, LH or Cr if its a counter unit.
stageharbor is offline   Reply With Quote
Old 10-01-2009, 03:06 PM   #8
JaayTeee's Avatar
2002 baja 33 o/l 575sci's
Quote:
Alpha and Bravo engines( pretty much all stern drives too)
rotate LH....the clutch's wont work when the input shaft
turns RH on alpha's and bravo's.
Rotation changes are all done in the drive
JaayTeee is offline   Reply With Quote
Old 10-01-2009, 04:13 PM   #9
1BIGJIM's Avatar
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Pachanga-27 Twin 502s
Not true, They only make Bravo's in standard rotation. The rotation is changed by changing this shifter cable on the shifter lever.
Griff explained it the best. He lives in Omaha also so he must know what he is talking about
1BIGJIM is offline   Reply With Quote
Old 10-01-2009, 04:33 PM   #10
JaayTeee's Avatar
I was addressing the question on ENGINE rotation.
Alpha's and Bravo's will not work when
the input shaft is turned R/H. ( opposite of normal)
The clutches operate in a one way fashion,
turning them backwards just makes them over run.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
