Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-04-2009, 06:36 PM   #1
89 Baja 250 ES
Bravo 1 Stuck In Gear. Help !
I was idling in a shallow channel when outdrive struck some sort of object. After that, shifter stuck in forward. I have not been able to get in neutral. It's a 89 baja 250 sport ES, Big Bloock Chevy with Bravo I.
SidneyW
SidneyW is offline   Reply With Quote
Old 10-04-2009, 06:45 PM   #2
Fuelin Around
FuelinAround's Avatar
Sonic 31SS
I would pull it to see if the shifter fork is still attached correctly... Doesn't take buy about a half hour to remove and inspect
FuelinAround is offline   Reply With Quote
Sponsored Links
Old 10-04-2009, 09:25 PM   #3
Charter Member #1171
obnoxus's Avatar
2000 36 OUTLAW SOLD SHOPPING
hopefully its that simple
could have sheared the upper gearset shaft
keep your fingers crossed
IF YOUR UNDER CONTROL,,,,,YOUR NOT GOING FAST ENOUGH !!!!
obnoxus is offline   Reply With Quote
Old 10-05-2009, 05:59 PM   #4
Charter Member #601
Mr Gadgets's Avatar
1999; 28' Checkmate Convincer, 588" Dart, Procharger, MSII EFI.
Pull the back cap and see if things are intact..
Mr Gadgets is offline   Reply With Quote
Old 10-07-2009, 11:19 PM   #5
check shift cable behind bell housing where drive mounts and make sure its tight and not full of rust
jennys express is offline   Reply With Quote
Old 10-08-2009, 09:39 AM   #6
tssteph's Avatar
1998 AO 31
With the motor off (of course) grab the prop. I suspect it will not move either direction. Apply a little force to the prop and you will probably hear a noise in the upper if you can get it to break free. You will have to try both directions. I t will take some force though, everthing is in a bind in the upper. Probably a broken thrust washer or gear floor.
tssteph is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
