Quote:
Originally Posted by buck30
has anyone ever placed a tr in place of a trs? i've blown my third trs lower unit so far. i have a complete tr drive in great shape and plan to throw it on for a test ride. it is said that the tr drive is alot stronger then the trs. other than being about two inches lower in the water and having to use another prop i cant see why it wouldnt work. has anyone ever done this swap? my boat is a 1979 24' pantera with a procharged 540" bbc.
Whats blowing up on the lower?? Most probable is the lower gears. Proper setup is critical to the lowers surviving. I'm assuming your blowing up a right rotation drive? You cant just swap out lowers like with a Bravo. The top bearing on the TRS lower has shims in the upper unit to achive proper preload.
The right rotation lower has its driven/prop gear facing outward from the pinion, this puts the gear in a weaker part of the bullet. Setting up the right drive with a hard shim in the lower(instead of the crush ring) stabilizes it and increases gear life.
You can also try running a left rotation lower, these are stronger because the drive gear is behind the pinion gear and in the strongest part of the housing. You would need a new LH prop though, and it might throw off handling, because both the motor and prop will be spinning in the same direction.
Again, setup is very important to survival if your running any kind of power. But I think if you have a good set of gears, a good housing, proper setup and good driving habits, you should get some life out of a TRS lower. Being a single engine boat with some HP is going to be a big load on any outdrive. Good luck.
LE
