Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-25-2009, 11:45 AM   #11
Thanks, I see A-ok ! What size wheel do ya think would work best for ya so we can all keep an eye out ? ! J - and are you going to use the prop. adaptors in the future. If ya know of a used set my bud that is runnin some #3's is a lookin. "knee" any data yet ?
I'CE is offline   Reply With Quote
Old 11-25-2009, 02:43 PM   #12
Car Biz's Avatar
311 Formula Kaama
Quote:
Bruce,Ben,and I all agree that i need a 18 X 29,30,32 4 blade. If i can find a 18 in a 19 spline i will do that. if not i will have to have some adapters made or buy some........... Bruce wants his back
And yes KNEE give us some data!!!
Car Biz is offline   Reply With Quote
Sponsored Links
Old 11-27-2009, 06:18 PM   #13
1984 Excalibur Cat
I am tring to figure out what pitch prop are on the boat. All I know is they were 4 blades and port had a 2 inch hairline in it with a stamp of KME 986// J 655 & J 340. The Starboard prop has KME987// J 340. The ratio is 23 outer- 35 inner on port and 26 outer and 35 inner starboard. They are not counter rotating but not a clue why they have different ratio.
kneeslider74 is offline   Reply With Quote
Old 11-27-2009, 06:20 PM   #14
1984 Excalibur Cat
I am tring to figure out what pitch prop are on the boat. All I know is they were 4 blades and port had a 2 inch hairline in it with a stamp of KME 986// J 655 & J 340. The Starboard prop has KME987// J 340. The ratio is 23 outer- 35 inner on port and 26 outer and 35 inner starboard. They are not counter rotating but not a clue why they have different ratio. I would guess them to be 34 pitch.
Old 11-28-2009, 11:03 AM   #15
302 kaama formula sold/33 formula ss
I cant understand what 23 outer 35 inner//// and 26 outer and 35 inner means where are you getting these # from. If you turn the h bar on the inside of the boat by the u joints how many revolutions is the prop turning. If you have someone look inside at the h bar while you turn the prop that will give you an indication of your gear ratio. eg. 8%. 13% 18% overdrive or underdrive Bruce
BOATMAN302 is offline   Reply With Quote
Old 11-28-2009, 11:06 AM   #16
Dont use that prop with the hairline crack in it. I did that and it bit me by breaking the forward part of the rear housing on the drive making a real mess to the tune of $20.000 after it was all said and done
Old 12-15-2009, 05:40 PM   #17
1984 Excalibur Cat
I thought about repairing but am going to look for a different set of props anyway. boat is in storage right now and is toooo hard to get at but the #'s are gears that cxassell eng. cut for the previous owner and i am going to work with BBbldes to nail the set up this spring. and if after all is said and done it doesnt have the potential to hit triple didgits I will end up starting all over.
Old 01-07-2010, 12:06 PM   #18
don
Just in case you want a spare Kaama, I have one that was just redone with 1-1.89 gears and 2 sets of shaft seals with a boot.
don is offline   Reply With Quote
Old 01-22-2010, 05:04 PM   #19
1984 Excalibur Cat
what do you need to have for your spare?
Old 01-29-2010, 03:52 PM   #20
sac
I have (7) 19 spline props for sale,have no use for them anymore
(2) 4 blade Rolla's, 17" diameter, not sure of the pitch,they are a matching set, left and right,appear to be upper 20's in pitch
(1) 4 blade 16.25 X 26 L.H. A961L 15 degree
(1) 4 blade 16.50 X 26 R.H. A962R 15 degree
(1) 4 blade 17.00 X 26 R.H. M378R
(1) 3 blade 17.50 X 29 L.H. K983L
(1) 3 blade 17.50 X 29 R.H. K984R
sac is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
