Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-19-2009, 08:12 PM   #1
1986 Formula 357-SR1
Replace Gimbal Ring or Entire Transom Ass'y?
My Stbd. Gimbal Ring failed at the pivot points last summer & would have sunk if it weren't for the trim and steering arms. In the process it broke off big chunk of the Gimbal Housing collar so I replaced the entire Transom Assembly. The Port Ass'y looks to have been replaced at some point- it has a newer style gimbal ring w/ the u-bolt at the top, but its got some age on it too, and there's a hairline crack running above and below the u-bolt. I want to replace it over the winter but am wondering if I shouldn't just replace the gimbal ring and not the entire assembly. Seems to me the ring is what takes the wear and stress at the pivot points- the bell housing and gimbal housing don't really have anything to wear out. is there any reason to replace them if they don't look damaged from impact or severely pitted from salt? (NOTE: TRS)
ctuck0659 is offline   Reply With Quote
Old 10-19-2009, 08:28 PM   #2
www.lakestclairrun.com
Irishtornado's Avatar
2003 Baja Boss 302 HP500efi's
I talked with Mark at BAM today and they have a kit includes, Gimbal ring,bellhousing,pins it's a upgrade kit to make the bravo assembly a HD Assembly
Irishtornado is offline   Reply With Quote
Sponsored Links
Old 10-20-2009, 07:39 AM   #3
Lakeside Restorations.com
Commercial Member
LAKESIDE RESTORATIONS's Avatar
I would recomend a new assembly. It is usually cheaper in the long run also you then have all NEW parts.. If you would like a price on one feel free to call me... Jamie / Lakeside 570-639-2628
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline   Reply With Quote
Old 10-20-2009, 10:07 AM   #4
hoozeyurdaddy's Avatar
2001 profile 280 cat
If the pivot points are not wore, I would change the bushings in the transom assy, and upgrade the ring and bellhousing.
and change the gimble bearing and seal also.
hoozeyurdaddy is offline   Reply With Quote
Old 10-20-2009, 03:09 PM   #5
99 sr24 htm
If you are looking to replace the whole transom assy. i have a very nice used std. for sale comes with everything only 25 hrs on it $1000.00 or make me a offer
dennis r is offline   Reply With Quote
Old 10-20-2009, 04:10 PM   #6
Sorry, I forgot to mention this is TRS. If anyone has a gimbal ring or complete assembly they want to offer, I'm all ears-
Old 10-20-2009, 10:16 PM   #7
WILD THANG
Harvey's Avatar
1991 Cigarette Top Gun
I have a left and right TRS complete gimbel and drive I'll take 2000.00 each. I bought a set of konrad drives, I'll be pulling these next month.
Harvey is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
