| OSO Sponsor |
| OSO Sponsor |
10-29-2009, 09:17 PM
#31
07' 38' Lightning
CB-BLR, Thanks for the quick reply. How is the whipple upgrade doing. Any problems? Would you happen to know what SCX are rated for in HP? I'm having a problem with throwing blades and blowing XR uppers looking for something to last.
10-29-2009, 10:08 PM
#32
Offshoreonly Advertiser
Quote:
I was told by IMCO it can handle 750lbs torque.
10-29-2009, 11:36 PM
#33
Chris
2009 Nordic Heat - 600sci - Whipple Stage X - SCX drive
My motor is down at Dustin's for R&D on upgrade stages 3-5. I have had no problems with the Stage II upgrade (aprox 730 hp).
Regarding the SCX... IMCO is reporting zero failures of the upper gear-sets to date. Some of these have gone on 1100+ horsepower motors. They did have some initial shifting problems that have been rectified with better billet parts.
I think the SCX upper is the solution for most of us that have been eating XR uppers. I don't think it will solve your blade throwing problems. Sounds like you need better (or a different style) of props.
Chris
10-30-2009, 12:07 AM
#34
04' Gladiator powered by Ford
How much extra stress is going to be placed on the gimbal with the extra weight and how is the CG of a boat affected by putting an extra 150 lbs (twins) that far out back on ITS?
Anyone with experience on this?
10-30-2009, 03:37 AM
#35
07' 38' Lightning
[QUOTE=CB-BLR;
Chris[/QUOTE]
Chris, The blades i've been throwing were 6 blades 3 Herings and 2 Throttle ups. The good thing is Julie stands behind there work with replacements. I like the idea that you can run a #6 blade with the SCX lower should stop that problem.
Bob
10-30-2009, 08:43 AM
#36
Charter Member #601
1999; 28' Checkmate Convincer, 588" Dart, Procharger, MSII EFI.
2112,
You can add an Imco Gimbal ring to your transom. They are now working on a solution for the trim indicator for the ITS.
That will be a relatively inexpensive way to beef up the transom assy.
Dick
10-30-2009, 10:01 AM
#37
Cold as a Blue Dog
little cat...BIG MOTOR
14 hrs so far trouble free behind a 900hp / 870lbf blower motor in a 4000lb 25ft cat. SCX upper / SC lower.
This was the package recommended by IMCO due to concerns of the bigger foot on the SCX lower at high speeds causing some serious stern lift when run on the surface.
Sure beats buying gear sets repeatedly
P.S. This thing shifts so smooth, you would think that there's a tranny in the boat.
Happiness is a Boat and a nice bit of Tail
10-30-2009, 12:18 PM
#38
Quote:
Originally Posted by Mr Gadgets
2112,
Dick
I have an ITS as well and was wondering how difficult the retrofit of the SCX upper would be.
I dont want to rip the ITS off the transom.
What else besides the trim do I need to look at?
UD
10-30-2009, 01:56 PM
#39
2008 F32 DCB Merc 700
F32 DCB
It will bolt right on with the shaft change
10-30-2009, 02:40 PM
#40
Charter Member #601
UD,
a different input shaft is used on the ITS. It is the Merc ITS input shaft, I believe. Add a couple hundred dollars for it above the standard setup.
Options include color, (silver, black) propshaft 1 1/4" or 1 7/16" Hub comes with it.
You will need a new helmet, reservoir, and the drive. If your motor won't idle down to around 800rpm.. you can install a shift interupter switch.
Thats about it. Like I said they are looking at the ITS trim indicator at this time. They should have something in the near future.. You will probably have to use their Gimbal ring to accomadate the trim sender setup?? Not a bad idea to install their HD gimbal ring..
Hope that helps.
Dick
