Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-25-2009, 09:49 PM   #1
38 Scarab AVS
Question Add'l Maintenance on Stelling Extension Boxes?
Hey guys - just wrapping up my first season with Stelling extension boxes. Is there any additional maintenance I should perform on them? I pulled the access panels on the sides and found a couple grease zerks inside. It looks like another zerk is conveniently located on a u-joint right where it passes through the transom. Any tips would be appreciated... thanks. SM
Shallow Minded is offline   Reply With Quote
Old 10-26-2009, 12:45 AM   #2
RIPSTA Racing Team
fireboatpilot's Avatar
88/08 32' Hydra Cat twin Bandit 540's, 700hp / 2008 66' Fireboat Independence 4-850hp
I'll be installing a set of the same this winter so this is a need to know for me as well. How did they work for you handling wise and what gains or losses did you get? I'll be going from std Bravo 1's to boxes and Imco -2 shorties. I'm starting with the boxes at the neutral position. Thanks!
fireboatpilot is offline   Reply With Quote
Sponsored Links
Old 10-26-2009, 02:40 AM   #3
32 Active Thunder
One zerk on the flange and one for the carrier bearing, assuming you don't have the sealed bearing.
http://www.stellingsmarineproducts.c...ucts/index.php
Then the U joints, if you can get to them. Thats about all there is to it.
Mine is a little different set up inside the transom since I have a driveshaft and a couple more zerks. I ahve been told to grease them every 25 or so hrs.
Griff is offline   Reply With Quote
Old 10-26-2009, 09:06 AM   #4
38 Scarab AVS
fbp - I can't really tell you of any gains since I bought the boat with the boxes on it. From similar boats without the boxes, I'd guess I'm 4-5 MPH faster. I'm running standard Bravo's, but would like to get into XR's at some point. Good luck with your upgrade.
Griff - thanks for the info... like usual, I should have just came straight to you. I forgot your AT has boxes, too. It takes a contortionist, but I think I can get to all the zerks.
Old 11-03-2009, 10:25 PM   #5
98 ActiveThunder Tantrum
what drive shaft? does that mean you don't have the carrier? Can you explain? I am getting ready to go over my settup so I am compiling info.
Do you have a "drive saver", if so on the motor or in the box?
My Addiction is offline   Reply With Quote
Old 11-04-2009, 01:31 PM   #6
32 Active Thunder
I have the standard Stellings set up except my engines are moved forward about 12-16 inches and use short driveshafts similar to what would be used on a staggered engine. I do not believe there is any drive saver, and definately nothing inside the box.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
