Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-07-2009, 06:28 PM   #11
RaggedEdge's Avatar
'06 35 Lightning Merc HP 525's aka The Black Biotch
Quote:
Originally Posted by nordic95 View Post
Yea but thats to easy...I did look into the transome pick up but with a notched transom they mount them on the lower notch and then run hose thru bottom of boat,or top of notch so to say. I didnt want to add hole thru boat if I didnt have to.
Anthony
That was the reason for the "hook it to the standard pick-up hose that runs thru the transom" comment. No more holes in the hull.
Low Tech and Proud Of It
RaggedEdge is offline   Reply With Quote
Old 11-07-2009, 08:38 PM   #12
GO4BROKE's Avatar
2002 Sonic 386
I second the GPS speedo.
GO4BROKE is offline   Reply With Quote
Sponsored Links
Old 11-08-2009, 03:14 AM   #13
32 Active Thunder
I had a notched transom on the Pantera with a separate water speedo pick up. The speedo tube was drilled at least 6inches above the water line and the hose was just run longer. Tou definately don't want it going through the transom below the water line. Connect the pitot tube assembly to the tube that runs through the drive as said or for about the same $$$ as the pitot assembly, get a cheap handheld GPS.
Griff is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
