Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-05-2009, 03:51 PM   #1
2004 31 Formula PC and a 1988 28 Pantera
Props for number 3 drive
How expensive are props for this drive?
bigboat28 is offline   Reply With Quote
Old 11-06-2009, 12:25 PM   #2
props
what are you looking for? call me 309-925-4620 karl
kgz3 is offline   Reply With Quote
Sponsored Links
Old 11-06-2009, 09:13 PM   #3
MSW
Quote:
What prop shaft large or small have a couple sets of props for small shaft
MSW is offline   Reply With Quote
Old 11-09-2009, 05:06 PM   #4
Just wondering about prop prices for them, looking at a boat that has those drives.
Old 11-15-2009, 01:22 PM   #5
tcelano's Avatar
35' Cigarette Mistress
Prop Prices
I just picked up and old Cigarette Mistress with SSMIII's, and have been doing similar legwork. If you are content with three blade props, you can have a pair for of lower pitch models for 1200 or so. There is a set of 17.5x31's listed for $1800. Four bladers with 19 spline hubs are scarce, but you can run 26 spline props with adapters. This is the way I am going, and here is my logic:
I'm spending about $4000 for a set of 4-blade nearly-new re-worked 17x31.5's. I am going to be installing 1000 hp motors. I know the III's aren't going to live past about 80% throttle, and I may put in some mechanical stops until I upgrade the drives to make sure I don't get carried away and end my season, but we don't run real hard or abuse the equipment much anyway. When the drives blow, I can go straight to a IIIA or V setup with a spacer, and I don't have to re-buy props.
If you are interested in 3-blades, Doller offshore has a pair of 3-blade 16.5x32's that they want 1200 for.
I have a set of 16.5x26 three blades that I am trading in on my new ones, and the shop is giving me $500 against them. The have a couple small dings on the leading edge, but nothing major. They are boxed up and ready to ship. I'd take $600 for mine if buyer pays shipping.
I also have a single 16.75x29.5 RH 4-blade 19 spline that is a heavier build (800 hp blades?), if you were looking for a single, or find a lone LH that is close enough to be worked into shape.
tcelano is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
