Max Machine Worx Modified XR
If you are going to cruise at 3500-4000 RPM, what will your torque be in this RPM band? This is a good question to ask all...."when your drive broke, how much torque were you making"? Our MMW Bravo XR's have not broken in 8 yrs but we only have about 650 lbs torque with a 9500-9800 lbs boat (includes crew and fuel).
There are lots of Bravo drive failures with 700+ lbs. torque and 10,500-11,000+ lbs 38' boats. Some large CI BBC's can make 800 + lbs of torque.
Bravo drive specialist, do you think there is a direct relationship between drive failure and the torque made with big CI?
Advantage 575,
Check this thread out,there is lots of info/insight for you-http://www.offshoreonly.com/forums/drives-lower-units/179738-800-900-hp-bravo-xrs.html?highlight=max+machine+worx
PM me if you want to hear about our time with Max machine drives-truth not made up B.S.
max
Guys I Have Big Hp Behind A Max Modded Bravoe Upper With Strait Cut Upper With There Tower And Top Cap, With A Max Billet Lower 1.35 Ratio And I Have Never Had Trouble My Torque And Hp R Above 1000 ,, And I Cut It No Slack ,, Tall Deck Blown 598 , 1471 With 1050s , 25 Talon , Those Boys Out There At Max Got There Shet Together, I Vouch For Them ,
Had a boostpower quad rotor 598ci in a 27 eliminator and broke 3 in a month. Never broke one cruising or while running on the big end, But everytime I would hammer on it from 60 mph it would break while excellerating. The guys at max said the motor made to much torque in the midrange. was running a BBlades bravo 32
