Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 02-12-2010, 08:07 AM   #1
itbs's Avatar
bravo 1/bravo2
is there any difference bravo1 upper to bravo2 upper is one better than the other or are they the same upper
itbs is offline   Reply With Quote
Old 02-12-2010, 10:36 AM   #2
Charter Member #601
Mr Gadgets's Avatar
1999; 28' Checkmate Convincer, 588" Dart, Procharger, MSII EFI.
They are the same upper, but gear ratios could be different..
Dick
Mr Gadgets is offline   Reply With Quote
Sponsored Links
Old 02-12-2010, 12:32 PM   #3
itbs's Avatar
200.1
Old 02-12-2010, 07:04 PM   #4
Charter Member #601
Mr Gadgets's Avatar
The 2:1 uses the 32/27 gear set, same as used for the 1.5 upper.. Just checked the chart. It would be the same upper then.. Is one newer than the other?? What does the serial number begin with?? OL or OM? OM and newer has the X gears in them..
Hope that helps.
Dick
Old 02-13-2010, 02:23 PM   #5
itbs's Avatar
on a 2000 sea ray 290 150 hours mine are 1994 450 hours
Old 02-13-2010, 11:40 PM   #6
Charter Member #601
Mr Gadgets's Avatar
I can't remember exactly when the X gears came out, shortly after the XR came out. Anyway.. check the serial number.. if it is OL, then it has the thin floored gears.. If OM, then it has the newer better gears.
Dick
Old 03-08-2010, 08:02 AM   #7
itbs's Avatar
bravo2s are ol is a drive with od349764 any better
Old 03-09-2010, 05:39 AM   #8
Charter Member #601
Mr Gadgets's Avatar
OL and later have thin floored gears.. OM and newer have thick floored gears. OD would be an older version.. They made changes in the castings of the upper cases, over the years.. The newer the better when it comes to upper cases.
Dick
Old 03-13-2010, 06:35 PM   #9
itbs's Avatar
if you had to chose witch wood u take twin 540s in 27 datona cat
Old 03-14-2010, 10:50 PM   #10
Charter Member #601
Mr Gadgets's Avatar
If I had to choose, I would tear them down and inspect.. But without that, I would go the newest one.. the OL. I have installed a lot of steel towers in the OL cases.. and upgrade gear kits, makes a nice drive..
Dick
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
