Whats a good replacement for bravo1 that will hold 600hp??
if you have engine room you can run this set up for $35000 less then the asd6...
take a look
http://www.offshoreonly.com/forums/s...eson-asd6.html
I can also give you the email of 3 guys with asd 6's from 9k each to 5k for a set of ccw 1721 drop boxes...
btw
in line drives can take more power,, there are no gears, no chains just a shaft and ujoint. that is why they sell a hi power gear set at arneson... that being seed most mono hull gas out drive boats are not a good fit for in line arnesons.. scarabs being one make.
