bravo II ready to go
ran into a snag on the driveshaft bellow. my question is on one end is the clamp other is a ring that needs pushed into the bellow. on that end there are two groves that can both be slipped on over the gimble housing, one grove closet to the end, and the other near the ribs? i also called the people i got it from and they gave me two different answers! thanks for the help
Lakeside Restorations.com
Commercial Member
The indentation on th clamp end on a bravo goes over the bump on the flange on the transom assembly and should snap into place. The indentation on the ring fit end snaps into the bell housing ridge, then the ring goes in to secure it in place..
Not to be a wise azz, but if you are unsure, taking it to a pro to at least have him put the boot in properly would be good. You dont want to have done thru all of that work & expense to only have a leak that could cause damage..
Hope it helps.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
hey jamie,the problem i have is im getting different answers. i can get that bellows grove to the gimble housing on either grove. the inside one would be alot easier to install the silver ring,but it sounds like i need to use the outside grove. i have been a mechanic , dragster chassis builder for 34 years now but just learning to work on my own boat. you know how it is you dont trust anyone to work on your own stuff. is there any secrets to getting the ring in? thanks again dan
Commercial Member
