Part number for Gimbal Bearing for a 1997 Bravo one
Need to replace them both for preventative maintenance. Want to order the right ones. I was told that Merc stopped making the greasable ones and that I should go to Sierra. Part numbers anybody?
sierra# 18-2100
i dont believe theres a lifetime lubed bearing.grease is the life of anything that moves.if thats not the case why dont we just leave the oil in our boat forever?? mercruiser u-joint and gimbal bearing grease is what ill always use.pretty resistant to moisture
you can run the 18-2100 or the 18-21005 0n older bravos and alpha gen 2 drives.. if you have a late model bravo serial number OF730000 and above or xr drives you need to run the 18-21005.the inner race lip that touches the end of the drive shaft closest to the u-joint end has been machined down a couple of thousands so as not to bind under full negative.hope this helps
Thanks for the insight. Is it true that the 18-21005 is also more "heavy duty"? I have had two people, including yourself, tell me to use the 18-21005. Ebay has them for 60 bucks a piece with shipping.....
Ohh it's a weak link. Just bought the boat and the surveyor said the port one is bad. After yanking the drives there must be a bad bellow at one time or now because it looks fairly nasty up in there and my U joint on the drive has some surface rust not pitted. So I am replacing both bearings and replacing u joints on the port drive.
