Flywheel and couplers for B1 question
I built the hp500's in the spectre over the last month and am about to send the internals for balancing, I want to change the flywheels and couplers because the factory flywheels weigh 43lbs!! And the couplers are the weak rubber aluminum standard junk. I've looked at Teague and CP performance, and if their lightweight flywheels will work that's fine, but what should I do about couplers? The engines will make around 675 NA
Offshoreonly Advertiser
We use the Mercury Steel Core P/N: 861523A20. They hold up well to 800HP+.
Long snout!
