Has anybody broke outer transom plate?
#42
Charter Member #601
My thought was if it was an XR and a tooth came off, the pinion gear sometimes shears off the front of the XR case.. Then a chain reaction. But you are right, the sheared edge probably tells the story.
#43
Just wondering if the screws broke, pin backed out, and put too much side load on the helmet and this happened. You know the deal, $.16 part causes $8K damage.
Are there marks on the inside edge of the pin from the U joint or something "blasting" them out? Later gimbal rings have 4 screws.
Are the gears broken?
#44
If the screws were backing out, they probably would of fell out and not broke the heads off. It was either the helmet then the u-joints, or the u-j then the helmet. Either way, water under the bridge now.
LE
