Standard SCX caused engine failure????
It could certainly have contributed, but only if the engine wasnt setup right to begin with. The increased drag of the lower could have scrubbed enough speed that trying to spin the same prop lugged the engine at WOT, causing detonation and engine failure.
Blaming it on the drive is a builders way of trying to get out of his responsibility. Had the setup been better from the start, it shouldnt have happened regardless of the drive that was used.
Kinda my thoughts.
A boat is like a motor home always going up hill. Always under load.
I took a friend out for a ride and he said, "we just did a full throttle dyno pull for 30 minutes".
Set up error!!!
Set up error!!!
Chris
Here is my take...
Since the new SCX lower was designed from scratch on a hydrodynamic cad simulation program...I do not think that the lower being bigger is causing massive amounts of drag as compared to a SC...thus slowing boats down ...I think that it is much more efficient at getting water to the prop...therefore loading the prop harder...with more and cleaner water...ie less cavitated water at the prop...and more of it.
This makes spinning the same prop as before...much harder to spin.
I am not sure that this increased water flow to the prop is a good thing or not.
High speed naval torpedoes actually inject air out the nose of the round tipped torp.... in order to let the torpedo travel in a cavitating mode...and go faster.
Chris
Chris
