SCX-4 Black Thunder 46EC 750hp! (Ryan9154)
PF Marine
Hey Ryan, if you you wouldn't mind giving an update and what you've gone through as far trying different props, rotation, and spacers as there are some people who are interested in what you're going through.
k here we go drive height started at 3/4 in below running surface at neutral trim.Spun props out boat didn't like that acted like the bow and stern were fighting each other.Spun in boat had bad bow steer added 1in spacer still spinning in boat plans and handles like a dream.So we ended up 1 3/4 in below running surface at neutral trim and spinning in. Props tried 30's ran 78 at 4800 tried 28's ran 79 at 5600 on rev but had 5 people going to run the 30's again because found out this weekend that i needed to trim farther than i was weather was crappy when we tried the 30's so only ran for a few.I would recommend these drives just going to have to be patient as far as getting everything dialed in i think the end result for top end will be 85 to 87 mph so we will be 5 mph faster than the xr's and have a good piece of mind on the drive strenght.Hope this helps.
He was only out 1 day this weekend with a full load of friends. Even though ryan is one of the better drivers out there he admits he is getting better dialing in the new setup everyday. Not much new to post besides better handling/comfort/confidence everyday.
So nothing new as far as speed gain, getting on plane with the -4's, how they operate, easy to shift hard to shift, give us the scoop.
