Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 7 of 7
  1. #1
    My Boats:
    checkmate 251 convincor,checkmate 253 convincor, 50 gibson
    Join Date
    Nov 2005
    Location
    Fredericksburg, Va
    Posts
    2,613
    bravo 1 delay going in gear
    just had engines out for rebuild, drives worked fine, now have a 5 sec delay going into gear in one ? did not mess with cables, only fluid change to drives ?? 1998 35 fountain ? thanks for any idea's Rob
  2. #2
    I hate the winter!! Platinum Member Vinny P's Avatar
    My Boats:
    99 checkmate 259
    Join Date
    Jul 2001
    Location
    long island, new york
    Posts
    2,610
    Rob,
    I have been down that road before. It will be difficult to tell what it is without some real investigation. I would start by disconnecting the drive cable and attempt to shift the drive ( with the engine running ) by pulling / pushing the cable. It is possible the cable just stretched a bit and needs to be adjusted. Merc makes a tool that sets the cable where it is supposed to be, but it requires having the drive off. I had success with just playing around with the adjuster until the drive shifts smoothly. if it doesnt shift by manually pulling the cable, then I would take the rear cap off and take a look at the shift fork and all related pieces in there. If it all looks good, you will have to tear down the upper and check out the cone clutch, springs, etc..
    Good luck..
  3. #3
    dcb
    dcb is offline
    My Boats:
    2002 Cigarette Top Gun
    Join Date
    Aug 2007
    Location
    falmouth, va
    Posts
    103
    +1 check cable adjustment
  4. #4
    My Boats:
    2000 Velocity 260, 496HO
    Join Date
    Dec 2011
    Location
    Colonial Beach, VA
    Posts
    247
    Cable adjustment... Been down this road before....
  5. #5
    Platinum Member Platinum Member seafordguy's Avatar
    My Boats:
    Cigarette - Cafe Racer
    Join Date
    Jun 2006
    Location
    Seaford, VA
    Posts
    2,656
    I made a cable adjustment tool by cutting a slice in a paint stirrer.
  6. #6
    My Boats:
    Join Date
    Nov 2005
    Location
    Fredericksburg, Va
    Posts
    2,613
    thanks, checking now...had a issue like before...pin in linkage had worn, found it when it broke and did not come out of gear...that was fun coming in to the dock !
  7. #7
    Charter Member # 55 Charter Member Griff's Avatar
    My Boats:
    32 Active Thunder
    Join Date
    Oct 2000
    Location
    Omaha
    Posts
    12,208
    Probably just needs a cable adjustment like was said. If it won't adjust out, then the clone clutch is going out.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
