Bravo 1 Trim Line/Hose Help
Have a bravo 1 with a leaking trim line/hose from the pump. Not sure if it's the send or return line. Figured I'll replace both. Suggestions on fishing these guys through the gimbal housing? Should I pull them from inside the boat out or from outside in? Looks to be really tight in there. Looking to also replace the distribution block where the lines come together. The sure don't leave much room to work.
