trs drive question
trs drive question
The line that goes through the hull from the fluid box to the drive popped off in the water n lost all my tranny fluid n won't kick in n outta gear ... Assuming no fluid is the problem with that but is there any thing I need to flush the drive or the tranny with to make sure there's no water in the system ?
Need more info, possible picture
Keep it simple, is the throw of the transmission cable allowing it to fully engage the transmission? I would disconnect the transmission cable. Start the boat on the hose. And manually put the transmission into gear. If it then engages it needs a cable adjustment. Make sure the transmission has F type transmission fluid, that it is the correct amount, not over filled.
Borg warner trans I believe ... It always worked before but i had to replace the ujoint shaft and bellow ... I'm gonna mess w it tonight hoping its just fluid level or an adjustment like you guys say . N type f fluid , how many qts by chance ?
