-3 to Bravo Drive
-3 to Bravo Drive
As many of you may know, anything shorter than a -2 on a Bravo drive creates a definite clearance problem and limits prop selection. Thought I would share some modifications I made to my Bravo to show what can be done with a little time and effort. I've seen a few threads on this topic but nobody has really detailed the process they took other than bolt on an aftermarket cavitation plate. I wanted a "factory" look and you can see the steps I took at the link below. A little welding and body work and I'll be done.
Click Here for Shutterfly gallery
Nice work! What year is your boat and what power are you running?
I see that you run the same prop as me (although I run a stock 24").
Please post the results once completed.
I mocked up a few pieces but didn't like the way they looked so decided to try it like this for starters. It won't be a big deal to add them later, if necessary. I'll know more this weekend.
