Pitted Drive Clean Up
Filler:
I first started off using Alvin Products Lab Metal (aluminum filler). This stuff stuck great and was as hard as a rock . But to finish sand with it was a pain in the ass. I spent a frustrating 20hrs on one drive trying finish sand the Lab Metal. I basically ended up die grinding it off the drive, I would not recommend it.
I am probably going to get flamed for this, but I finally ended up using Dynatron Dyna DeLite. I filled all the pits on the drive I had not touched and then skim coated the areas on the other. Sanded great, primed and then painted. The DeLite is similar to bondo but it is suppose to be water resistant compared to bondo. I had a piece of aluminum with DeLite stuck to it sitting in a bucket of water for 3 months with no ill effects.
Use a quality paint. DuPont ChromaOne or PPG single stage
http://www.harborfreight.com/air-too...gun-66222.html
