2" imco shorty bare case kit
http://www.imcomarine.com/cal_store/...-case-kit.html
If i buy this "kit" which comes with the vertical shaft and bearings can i take the prop shaft and bearings out of my bravo 1 lower and install in the new case? Thanks, Richie.
Confirming that Ran-Dom is correct. Given that you are updating your drive, since you have it apart, why not do it right. Give these guys a call and get the internals from them. Buy the BARE case and have Max Worx shafts and bearings, etc. At a minimum, purchase a 1-1/4" prop shaft from IMCO. Better material then Merc and larger in diameter over the stock 1". All you have to change on the prop is the hub.
http://www.maxmachineworx.com/
