upgrate alpha 1 to bravo xr. transom.
sprink58, thanks for that, very helpfull, did u get the drawing/template with the new drive?
wonder if mercruiser supply it seperately. could u post the drg number, its just too small to make out .
Thanks.
Thanks.
No template, but A few years ago when I did a transom I picked this up for drilling the holes, set it for 90 degrees and your holes are perfectly aligned. Handy little tool to have around.
http://www.harborfreight.com/angle-d...ide-95622.html
Is the Bravo Drive Longer..Will it affect the x dimension? If so what length shortie would correct it.
Chris
Chris
dimension between upper and lower shafts is the same for STANDARD length alphas (gen 1 and 2), pre-alphas and bravos. alpha ss and bravo shorties are shorter to raise prop shaft height. TRS is longer. shift bracket on exhaust. can alpha be used for bravo?
http://www.wikihow.com/Make-and-Use-a-Drill-Guide
-Wally
-Wally
