SSM service in the mid-west?
That's Odd. Considering Gary K. has all the new gears and propshafts available for them, most bearings I was told were shelf bearings available thru a bearing supplier.
Anything wrong with your drives now RBesola? With the new Net forged gears, and 26 spline propshafts available, I think the IV's that are still around can be upgraded to take some serious power.
Call Dubberts Outdrive Service in Port Clinton ,Ohio 1-419-732-1778... Ask for Jim Dubbert Can work on any speed master drive and is a certified Merc. Master Mech. along with his whole crew. May be a little closer to you and you can take the turnpike or I-90 to his facility.They are located at 2344 E. Harbor Rd. Port Clinton,Ohio 43452 He is a OSO member and owns a Cig top gun. Good guy!!!!!!!
Jim
Jim
Pretty much what i thought.which will work out well since were changing both upper sets to get the overall ratio corrected.Garys been a big help with both parts and advice as well as setting everything up with Craig
