Price for a new gimble ring
Hello,
I have a 05 Sunsation 288. My dealer told me last fall I need to replace the gimble ring (my steering is very loose). Before I call them I would like to know what replacing this usually costs. My engine is the 496ho.
The engine has 350 hours. Two seasons ago they tightened the bolts. Last season after winterizing the motor the tech told me he can't tighten it anymore and said I should be good for this summer and seriously consider changing it in the fall. My impression was the bolts shouldn't be tightened after the outdrive is installed. I take care of my boat and thought that this was early to have this replaced but my steering is very loose.
Charter Member #1171
nuts should be kept at 55 ft lbs always
Figure 2k-2500 depending how hard it is to get your engine out and if you need a swivel pin
may as well do bellows and shift cable and swivel pin seal while its apart
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Engine shouldn't need to be pulled to change the gimble ring. Still though I would bet it's at least 2K. A new ring alone is like $900.
Engine doesn't have to be pulled ...but should be, to do it right . Mercruisers "fix" with drilling the gimble housing and using a dull chisel for working the steering shaft nut is not the best way .
Current list on ring is $994.29 you usually need the steering shaft $399.92.Add cost of boots, steering shaft seal and other small parts ...It can and will add up quick
Goto JRMARINE.com. It will answer every question you have. They have a templete you can use to cut and get to your swivel pin. I just completed this job and it was super easy. The gimbal ring is whats going to cost. If its not cracked, JR Marine can fix it like new again. Give those guys a call, super good people.
