Definative cause for cone clutch to stick to gears on a bravo drive??
Has anyone actually ever figured out 100% why a cone clutch (newer style 5 slot) would randomly act up/stick etc and what the cure is? Last year at end of season my boat went into reverse slow a couple times and then at end of the day backing off the river bank to put on trailer stuck in reverse so hard that I broke shift cable trying to get it back into neutral. Tore it down, nothing bound or stuck what so-ever, everything looks like new still, cone clutch has almost 400 hard hours on it, going to install a new one as good measure but not convinced it actually has anything wrong with it. Obvious things to save your time posting-NOT shifter adjustment as would NOT move to neutral position without putting enough force into it to break the cable, shift fork / cam wedge has virtually NO wear , linkage/ vertical pivot pin nice and smooth, detent ball greased real well and looks like the day it was installed, Smitty
Sheeesh, there's no making you happy. For so long I've heard you complain about no movement and now that it moves you complain that it wont stop. lol
How about the clearance between the snap rings in the cone shaft?
Or the threads on the cone and/or shaft being a bit worn creating a bind. More so, the shaft has a slight twist???
Dunno
Dunno
Cone shaft was a new billet Max worx about 50 hours or so ago, cone drops on it and almost turns from gravity if its lubed and u give it a little start, the spirals on the cone itself have some wear but I don't have a new one right now to compare side by side, ordered a new one and will put it back together with it with hope it helps but I don't usually throw parts at stuff hoping that it fixes it. I have worked on about 10-15 Bravo uppers in past 10 years but have never had one where someone says it stuck in gear. Have seen that complaint on here but never heard a final result of where replacing a cone fixed this problem, Smitty
I hate the winter!!
Smitty,
I know you know what the internals of a Bravo is supposed to look like, so I wont go there. I am thinking of another possible issue. Is it possible that there is too much load on the clutch , making it difficult to come out of gear? Maybe the engine idling too high? Maybe too big a prop?
Smitty,
I hate the winter!!
Yeah, I figured you would have thought of that possibility, I was just throwing out the only idea I had. I agree with you on making sure you found the problem, rather than just putting it back together and hoping. Mechanical repairs were never easy to do and I dont see them getting any easier in the future.
At work, I pulled the heads on a pair of 525's in a 39 OL. Put them back on this week, found the starboard engine wouldnt refire. Port was fine. No spark on starboard engine. Went crazy for several hours, had another mechanic in there with me for a while. We swapped all ignition related components with the good engine, still nothing. Started tracing wires, we found the trigger wire from the crank sensor to the ECU to be open. WTF!! How does stuff like this happen?
Like the saying goes, if it were easy, everyone could do it!!
Good Luck in your search.
