SSM #5 drive intall >
SSM #5 drive intall
SSM #5 drive intall
Old 08-21-2013, 12:31 PM
Charter Member #394
SFOcean's Avatar
Yep, Slim Shady's #6 propshaft is about 2" below the hull. You can see it in the avatar.
SFOcean is offline
Old 08-21-2013, 05:51 PM
cougarman's Avatar
Originally Posted by FORMULAfast
Has anyone ever ran a 28 ' magnum style hull with a SSM#5 drive on a singe engine making big HP ? If so where do I start with the prop? The engine is a 540 ci BBC W/twin turbos running 10-15 lbs of boost. The prop shaft centerline to bottom of keel is 1 1/2" the boat is setup with K-Plane tabs and full hydraulic steering. Boat weighs in at 4,500 lbs and the engine is in the 1,100 hp range. drive ratio is 1.34 engine RPM is 5,800-6,000 with rev limit at 6,500 I have discovered that the props for this drive can get rather pricey so I'd like to see if anyone has a good idea of where to start. I'm going to try a merc 5 blade cleaver 16% rake 18" dia 31 pitch just to see what it does. Any impute here would be great thanks
For Bill's 30' Checkmate with the Twin Turbo 1,500 hp the 3 blade prop Runs the best.
Also as I said in the earlier post, lots and lots of testing,.....the drive kept getting lower
and lower and lower.
12" Stellings Extension Box
#6 Drive DrySump / LH Rotation
Bullet is about 4.5” below the bottom of the boat
1:24 Ratio
16.5” Dia.
28” Pitch
cougarman is offline
Old 08-22-2013, 07:25 PM
Hey guys sorry been out of town but I read what you guys said here and I really would like to get together with you and pick your brains......
I will be out on the bay fri afternoon testing and if all looks good I will be out sat and run the fun run.
if testing doesn't go well I will be riding shotgun in my buddies 33' cougar so one way or the other I will be there.
as for the bullet mine is 1.5 below the keel now but I can add spacers to shim it lower. I'm already to install an extension box this winter too.
FORMULAfast is offline
Old 08-22-2013, 07:32 PM
i have a ssm extension box i might be selling if you need one.
ridefast77 is offline
Old 08-22-2013, 07:37 PM
Is it the stelling box? if so I'm interested
Old 08-22-2013, 07:40 PM
Ok I picked up a 28x17 4 blade and a 31x163/4 4 blade I'm still looking for a 3 blade
I have a 1.34 ratio so I'm thinking the 28-31 pitch range will be a good starting point and I know the dia can be cut down
Old 08-23-2013, 08:40 AM
cougarman's Avatar
The late Dennis Cavanaugh built Bill's three blade propeller for his 30' Checkmate.
There are allot of things that are not normal about this prop to perform the way it does.
Dennis sorted it all out.
http://bblades.com/dennis-cavanaugh-tribute/
Brett Anderson paid close attention to this prop when designed and now has all the specs on it.
Brett has also re-tuned it a time or two over the seasons
Old 09-11-2013, 02:32 PM
Offshoreonly Advertiser
bbladesprops's Avatar
I remember it like yesterday. 1998. Dennis had a picture of that prop on his wall in his office.
We have done numerous similar builds over the years. Most have been 4 blade versions.
Thanks cougarman
Brett
[email protected]
bbladesprops is offline
Old 09-27-2013, 01:53 PM
ive got a 29 pitch 17" 4 blade, your more than welcome to try, ive got a 28 ft cat with a #5, 930 horse dealing with the same issue, im down by cadillac so not ot far from ya,
lerg948 is offline
Old 02-22-2014, 10:25 PM
Working on getting my drive height right with a 10'' #6 box with a SSM #4 drive. How did yours come out?
