SCXs drain plugs
You have to separate the upper and lower. It's in there somewhere. I'm not gonna worry about it. My drain plug magnets looked perfect after 80? hours Upper gears show NO signs of anything, darn near looked new.
OK Thanks, I'm not going to worry about it either. When I changed the Torco at 6 hours and at 25 hours it looked like the day I put it in there. Im at 40 hours now, I'll change it in the Spring before I take it out.
MarkDonzi has probably close to 50 hours on his.....oil looked like brand new each time he changed it. He is having them separated to have everything checked, ill ask him to post up on what the magnets showed.
Imagine how much easier it will be to put in the lower drain plug after refilling when you have it attached to the end of a nut driver; instead of fubling around, making a mess, and trying to get that screwdriver in the damn oil covered slot.
I'd think a nice recessed Allen head would be even better; with hex on the outside incase you strip the recess.
