XR Value
Pirate of the Chesapeake
Some drives have no # on them.They can be ID by a visual inspection. Angle of the gears and type of retainer on the input to verify it is a X style case.JOHN SR
Would never pay 5k for a used XR when new ones can typically be found for 6500. (brand new uppers were on here last Summer for 3500) I've got two spares so I can rotate them as they wear, (pull the magnets and swap out when it looks like a Chia Pet)
They just have such a short lifespan that most (if not all) used XR's need work. (mine show heavy wear at 35 hrs...) Even if you do all your own work as I do, parts are rediculouly expensive. Just the parts to freshen up a lower are @ 1200 or so. Uppers can run @ 3k. Yeah, I've bought used drives but you just got to get them cheap and assume eveything inside is toast as more often than not it is. Even @ 35 hrs...
That is why I went with a bmax..... Why rebuild and spend the time when new ones can be bought for only a couple hundred more? I was thinking about just keeping as a spare in case crap happens and if there is not value I will keep it for just that. The serial number was checked and believed to be an XR according to mercrusierparts.com site listing. I am going to pull the cap and check the gears as well to see how they are cut. A very reliable source on here gave me the info on how to verify and end the debate.
+1 for the price they want for xr's compared to bravo1's it almost doesnt seem worth it. with the short life span of xr gears next to the cost for parts alone to rebuild them everyother season doesnt seem cost effective. grant it if you drive the boat like you own it and don't air it out you will keep it alive much longer. However when both bravo1's and xr's have a limited life span behind big power why spend thousand more for the 10 or so hours an xr may or may not get you. If your going to spend the money you might as well get it over with and buy the sixs, Bmax, or the best, arneson's. Just my two cents
So someone is thinking of buying XR's has a 32' whatever and is going to put a little power in it.To save from the problems he MAY have with stock bravo's or XR.He should go to B max #6's or Arneson's .$15,000 boat $20,000 st of motors.And so he doesn't have any problems with drives a 50,000 st of # 6's Sounds logical to me.
Engines too. If you or a reputable shop didn't built it, how do you know? Buyers beware
