Aluminum Powerboat 2x480hp, 2-speed transmission and surface drives
Did you read 7075T6's post a lot of good information in there, based on what he as done you are going to big on the drive and trans, you can use what he used ASD8 and ZF300ATS, the Yanmars make less power than the FPT560.
I personally think you can get rid of the trans all together and use XPower drives
http://www.xpowerdrive.com/site56/home.html
we all will be watching how they work on a boat this size and power, what's the cost, 35K ea. plus transom assemblies, steering and such. i think Jim Sikes spent close to $90K for a pair when using used transom assemblies to complete the XPower package. sounds like a bargain when compared to the reliable arneson direction marsu is going in that cost much less including the transmisions
arneson-industries.com
Offshoreonly Advertiser
Rik
Arneson Surface Drives www.arneson-industries.com
Just my 2 cents, unless you really overdrive the heck out of those the boat is not going to fast, no prop speed I say 50-60 mph. The other problem is those engines are huge (14.5 liters) if they are what I think they are? They are size wise smaller than a 3408 Cat but bigger than an 8-92, I think once you marinize them you would be better off with 650, 710 or 750hp 8-92's and they would weigh less? I'm sure you can get some good HP out of them but stock - too slow turning and not enough Hp for the weight to be a go-fast performance type drive train.
Sorry, Like I said my 2 cents
I can see what you are trying to say HabanaJoe and you are totally right.
But, from another side, I have an idea that I am trying to make work and have just gathered the components. All my focus is on revving up and keeping torque, but I am having a little bit of trouble concerning the propellers data, as manufacturers do not have info I could work with in my calculations.
Let's cross our fingers for good performance.
I ,m trying to understand the numbers you have , what exactly is the pitch number you calculated ?
In the info you said 28,5x 57 ,but 57 pitch seems a bit odd.
The rpm your motors are turning with the overdrive you want to use seems like your propellors are pretty big in diameter...I think you have to reduce that to 19-21 inch max because your boat is 46 ft long ,and 32 ft water line length ??? or is that a type error ?? anyway its not a 10ton cruiser your buiding , are you have a weight figure already ?
also the ratio,s between 1 th gear and 2 th is a large gap .
I,m not sure why the gap would be that big .. I also have 2 speed trannies from ZF ,1 th gear is 1,30 and 2 th gear is 1:1 , however I have a 3500 rpm max .
Take any 40' plus boat running Bravo drives, those little props can push a big boat pretty dam fast!
I tried what you want to do in 1983-1984 when everyone said "it's diesel, you spin a BIG prop slower and you go faster" When we hit a wall for speed they say "add more pitch" - they were all wrong! Smaller dia, less pitch, faster turning got us there.
I will agree that with today's 4, 5 & 6 blade props there is huge difference than 3 or 4 bladers of the day but hopefully it will work for you.
Guys,
I have been researching hydraulic transmissions and I am really tempted there.
I use them for concrete mixers, and think it will bring great benefits to high-speed powerboats!
Anyone has tried it before?
Any thoughts, except the lower efficiency compared to mechanical transmissions?
Then a hydraulic motor for each drive?
Jeff
Guys,
The advantage of them were you did not need a 2 speed tranny, even though at that time no one had a 2-speed tranny. You could rev up the engines with the throttles so they were in a good rpm range to make boost and then start locking up the tranny clutch packs. Once on plane you lock up the trannys and go!!!
They are also very good in turns as you do not need to use the throttles to slow down, just ease off the tranny pressure and props slow down but rpm stays high and you maintain some boost so when you apply the pressure to the clutches you have rpm and boost waiting for you - they could out accelerate most anything in a turn back then.
Like I said earlier, most of what needs to be done with diesels has been tried and perfected, you just need to take what was done and apply modern technology to it because the wheel will always be round.
