Drive oil
Running Mystic JT7 85W-140, Yes Mystic, in Mercury BlackHawks with 1:50 Gears attached to 550 Horse on each. Inexpensive enough to change a couple of times a season to check for any metals in the oil. Comes out a Pretty clear Red each time changed over the past few years. Was turned on to it by the late Brad Smith, SMITH POWER and will never change.
This got me thinking as i need to fill both drives and will probably change the fluids in my Duramax also seeing how I'll be trailering this season. Just found a local shop that has the Mobil 75-80 in quarts for the normal $12 and 75-140 in 5 gal pail for $180. Do you think there would be an added benefit to running the 75-140 in this situation?
Not sure why anyone would be surprised by results using MYSTIC? Very high quality lubricant company. I use their greases exclusively. Thanks for sharing! Brad was a bright guy and left a void when he passed, however his legacy will live on forever and keep this sport we all cherish going strong for years to come.
1 Post
joe,,they make the oil in 15w50 also for your big truck.. http://www.farmandfleet.com/products...l#.U2gJ2oHk98E
yep Mystik motor oil and gear oil, been using in the shop for over 2 years now, not a problem and worth the price as so far.about 400 boats have it without any problems that I have changed. O'Reillys just had a 8 qt / jug on sale for 24.99 for the motor oil15 - 40. I think something of Citgo oil is in Mystik oil products. No 100 % sure but do I know merc motor oils are made by Citgo and the merc premium gear oil is made by Citgo as well.
I have been debating on switching oil myself especially since I just went from bravo drives at 2 1/2 quarts each to ssm3 drives which hold almost 3 gallons each would be nice to save some dough. Only thing that concerns me is I thought I read somewhere that "marine" gear lube has a special additive to displace water. True or false?
