Snapped vertical (clutch) shaft Bravo XR
Well.....my extra HP finally bit me. While running WOT his past Sunday I heard my drive blow. Broke the top cap on all four corners. Shut the boat down and could smell gear oil immediately. Good and bad I guess, the clutch shaft snapped, at a 45 degree angle, spun on itself and pushed the top cap off. I thought for sure my gears came apart, but they don't even show signs of wear. There are pieces in the lower. Can I put it up side down and pump hyd oil through it to clean out? It still spins, however with the oil out I can hear a little noise.
I want to change this shaft myself (no wait) and it looks pretty straight forward. The merc pin spanner wrench for the input shaft retainer (xr is different than bravo) is 200 bucks, wondering if there is an alternative or if this will work http://www.amazon.com/OTC-6613-Varia.../dp/B000F5JMEA
Should I purchase an other stock shaft, or is there an upgraded shaft available from someone? Stock is 45-812773T02
Could have been worse I guess. What else should I be inspecting for damage? Drives have about 130 original hours
Get the Teague or Max Machine Works torsional shafts. Or, at least they are worth looking into since it looks like you already gave somebody your credit card number...
Since you need a top cap, seriously consider the Max Machine Works top cap with the 7/16 stud upgrade... Looks like you need it. LOL They are really nice pieces and I swear they added life between rebuilds (for me anyway) they obviously add rigidity since they are twice as thick as a conventional cap.
http://www.ebay.com/itm/NEW-OEM-Merc...#ht_720wt_1238
I use the Maxworx billet shaft and giant cap with 7/16 studs, after 300+ hours at 750-1100 hp it had cracks in it but I am sure a stock one would have broke long before that, good luck, smitty
Found more damage, nearly missed it. This is the first gen XR. The lower carrier bearing for the vertical shaft is in a steel housing that threads into the aluminum floor of the upper housing. When the shaft broke pieces went in the shaft needle bearing, seized it causing it to turn with the shaft. This basically caused the bearing carrier to over tighten into the floor and wipe out the threads. The carrier was floating. I have removed the carrier and am visiting a CNC shop today to see if they can repair. I really want to stick with the case that I have if possible, they are stamped and machined for the gear set and shims that are already in the case. Have any others had a problem like this?
Part #2 is what stripped http://www.mercruiserparts.com/Show_...FXZ%2DDrive%29
