Broken bolt in Alpha One >
Old 08-04-2014, 03:45 PM
Default Broken bolt in Alpha One
So I was working on my impeller and tried to remove the pickup tube in the upper and a bolt broke. The other three came out perfectly.
Am I SOL or can I extract that bolt? Or will three bolts be enough?
Please help!!
Jonesyfxr is offline
Old 08-04-2014, 06:20 PM
Come on guys!!
Please!!
Old 08-04-2014, 06:28 PM
Well it will be hard to get out if it's broke flush. I would try the 3 till winter then take it and get it fixed. I'm guessing u are talking about that plastic pc the tube goes in that would be upside down when the drive is on the boat? 3
So2fast5u is offline
Old 08-04-2014, 07:37 PM
No, the metal tube that goes into the upper.
I'm thinking 4200 around the base, then since her down.
Old 08-05-2014, 07:11 AM
coolrunning racing
mrv8outboard's Avatar
The longer you leave the broken piece in the harder it will be to remove. When I find this stuff I tell them it would have been easier if I got it when it broke not after it was left for later. It should be no big deal for a competent tech to remove and or repair.
mrv8outboard is offline
Old 08-05-2014, 02:55 PM
The problem is it's almost a foot into the drive. I can probably do it, was looking for advice.
