Arneson
Hi This is how they came from the manufactures in the 80s. I could rase the bhp to 320 per engine simply by replacing the injector pumps but id rather not change to much . They got it right for that setup. Unfortunately i am running out of cost affective options for replacing the 3 SSM this is reason i am looking and have probably committed to the Arneson units . Thanks Ricky.
arneson-industries.com
Offshoreonly Advertiser
Ricardo, you have any photos of this boat?
Arneson Surface Drives www.arneson-industries.com
[ATTACH=CONFIG]527492[/ATTACH][ATTACH=CONFIG]527493[/ATTACH][ATTACH=CONFIG]527494[/ATTACH][ATTACH=CONFIG]527495[/ATTACH][ATTACH=CONFIG]527496[/ATTACH]
[ATTACH=CONFIG]527497[/ATTACH][ATTACH=CONFIG]527498[/ATTACH][ATTACH=CONFIG]527499[/ATTACH][ATTACH=CONFIG]527500[/ATTACH][ATTACH=CONFIG]527501[/ATTACH][ATTACH=CONFIG]527502[/ATTACH][ATTACH=CONFIG]527503[/ATTACH][ATTACH=CONFIG]527504[/ATTACH]
[ATTACH=CONFIG]527505[/ATTACH][ATTACH=CONFIG]527506[/ATTACH][ATTACH=CONFIG]527507[/ATTACH][ATTACH=CONFIG]527508[/ATTACH][ATTACH=CONFIG]527509[/ATTACH][ATTACH=CONFIG]527510[/ATTACH][ATTACH=CONFIG]527511[/ATTACH][ATTACH=CONFIG]527512[/ATTACH]
[ATTACH=CONFIG]527513[/ATTACH][ATTACH=CONFIG]527514[/ATTACH][ATTACH=CONFIG]527515[/ATTACH][ATTACH=CONFIG]527516[/ATTACH][ATTACH=CONFIG]527517[/ATTACH][ATTACH=CONFIG]527518[/ATTACH][ATTACH=CONFIG]527519[/ATTACH]
set up right the arnesons should work real nice on that hull,magnum marine use to install the arneson and diesels in a lot of there similar hulls ran great and super reliable,if those 3 are really 1.1 the boat will run alot better with some gear reduction somewhere between 1.5-2.0:1
Go with a zf- 280 - a transmission with the 1.5 ratio. Get a set of acme 6 blade props. I have installed that combo in many boats with yanmar diesels and works great. The acme props are not very expensive either
The 240 a transmission we get you a down angle so that the engines can be mounted very close to level
