Help Identifying old Merc Drive
When I first looked at the serial it looked to be 4545516 but after I kept looking at it and zooming in the number looks like 4645516. The longer I look at it the more I keep seeing different numbers though. If it is any help the engine serial is 4499399.
Thanks for the help. Now on to inspecting it and making sure everything is in decent shape.
Is it correct that the TR drive run a 20" prop? Is the new 15" prop I have in a box good for the drive then?
Offshoreonly Advertiser
Yes hard to tell from the angle. What size is the prop shaft nut? 1 7/16 = TR2 (20" props) 1 1/16 = TRS (16" props) but I think I agree with BUP, TR2
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Check if the 15" prop even fits on the prop shaft. If it does than it is a TRS. TR has a larger prop shaft and I have never even seen a 15" prop for a TR. If it fits and there is little clearance then it's a TRS.
If you look at the tag it looks like it says 1.50 R for rt hand rotation and 1.50 ratio
I would say TRS but the measurement will tell all.
Which transmission is in the boat ? BW red tag 71 ?
