Help Identifying old Merc Drive
I have a 1977 Thunderbird FC-20L with a Chevy 350. I've been told that I have a TR-II drive but also have been told that it is a TRS-II drive. I have never worked on a sterndrive boat before and don't know much about identifying them. I was wondering what people here would say I have and get a for sure answer.
Here are some pictures of the drive.
http://imgur.com/a/6m0ck
According to this chart (http://www.bluewatermarinesvc.com/pd...year_index.pdf) the serial number that is off the drive which is 4545516 shows up as a TRS 280. But I thought the TRS 280 was the powerdrive package and that outdrive was different from the powerdrive package or am I mistaken?
The previous owner had a new prop sitting in the garage and it is a 15 1/4inch prop which makes me think that it is a TRS since the max prop is 16inches.
It is a TRS, measure the prop hub diameter and check it against any other standard merc prop hub at the marina , if it is the same then TRS for sure as the TR had a larger bullet diameter and hub. Also the TR was a 2:1 ratio I think, that prop looks like a 17 or 19 pitch that would be way too small for a 2:1 on an F20 350 combo
Biggus is right on with the mercy tans too
The problem is that the serial number on the drive and on the engine cover are both faded but the engine serial number is barely faded. So I can't tell if the second number is a 5 or a 6. Because if it is a 5 then that would mean it is a TRS but if it is 6 than it would be a TR.
BUP which list of serial numbers are looking at for reference? Because I have found some that say that the serial is a TR and others say it falls under a TRS.
