Broke another drive over the weekend. Opinions please
Check with George at AADS, he has new improved parts for Bravo and Alpha that increase power handling. He also recommends Amsoil Extreme Gear oil, I run the 75W110 in my Bravo.
I beat the crap out of my 1.5 SEI 'Alpha'. Turn a 21" and a 23" to 5400rpm and change.
I will holeshot with the best of them....about 2800lb boat. Wife, small dog, and a very small cooler.
I use 3 blade cleavers because my boat like them for some reason. They slip more than more normal props.
Blowing up Bravo's and Alpha's was a yearly ritual for me (different boats.)
Alpha's implode more from too high shifting rpm than anything else.
I will not go over 800rpm shift speed...ever again.
Lower than that is better...but 800rpm seems to live fine. Over that and Mr clunky clunky comes to visit.
That's my experience.
Note: This has been my only SEI as I haven't killed it. About 5 yrs old. It's first gear lube change at say 5-10hrs had basically no fuzz on the magnet. Mercruiser High Performance green gear oil. Drive shower. Never made much of a gear type whine noise like others say you get for first few hrs of SEI's.
Maybe I got lucky with a better one, I don't know. But when accelerating for speed, I don't go anyslower than a Micro second putting my throttle down thru the dash. LOL.
Used to with stock motor + stock Merc Alpha which I still used the 21" for normal boating, but a 19" for skiing/tubing. The 19" was a POS aluminum that reved like a 17" should.
If I where still using the boat for watersports, I would be using that prop for that.
I have a shed full of props, and use all different ones a bunch...prop that goes on depends on what type of boating we'll be doing for the day..including weather conditions (think wave height) we will be facing. Seriously. These little lightweight boats respond (good or bad) to the littlest change in anything.
Just Saying.....
I'm not into catching much air. I'll let the boat dance a little on small chop but I don't beat it's guts out when it's rough
