Small Chunks On XR Drain Magnet :(
That looks like a case of XR gear acne...nothing that a $ 1900 upper gear set, or if your lucky like Kurt a $ 750 lower gear set won't fix.....I've had a lot more uppers that lowers do this.
If you're running XR's, you need spares ready to go. We've got 4 drives and rotate them when the magnets start looking ugly..
Biggus....2 drives per season ?? Man you need to learn how to work those throttles
It's in my mechanic's hands now. He did inspect the upper gears and they look fine. We think the chunks are from the Imco lower. I hope to be back on the water by this week-end.
I'd pay the extra $$ to have him at least pull the upper gear set out and flush/inspect the bearings. The fluid from the lower does make its way into the upper. All it takes is a little bit of debris in the needle bearings to really make an expensive mess... I know first hand.. July 4th, I had a tower needle bearing get loose, get between the pinion and forward gear and all went to crap really quick...
Carl I just saw an old post on the "Microboats thread" where your speed was 85.80 MPH. Was this before you did the LU welding
and shaping? Was there a gain after the modifications or did the work just stop the "burning".
