Found a crack on the lower, a few questions
Did freeze damage play a bit of a part in the crack ?
bearing carrier retaining nut is more of the current problem at this point. Then most likely in due time gear oil leaks at some point . Trying to make it last & for something on the real cheap go have it welded
More like the drive was left Up, 'n the weep holes are plugged with crud, which held water in the exhaust cavity,....
I kinda doubt weldin' will work, as the case dimensions will have changed from the ice expansion,.....
Thanks for the suggestions everyone, went with a new lower from SEI and a Simrek shower. Only thing I had to do was tap and plug the oil passage that doesn't exist on my upper.
Just about ready for the prop and water.
