Lower drive discoloration
Called IMCO just to verify and they confirmed what the Bravo Shop told you. They said lots of things can cause this type of discoloration on the lower unit, so nothing to be concerned about. They didn't say ignore all discolorations, but this color can be called by lots of things, but not a heat issue.......knock on wood!!!
Nuke,
By chance did you buy any of the Ring-go the guy on here on OSO was selling to clean your hull? I'm thinking that's what caused my lowers and aluminum upper caps to turn rosey colored. That stuff is potent as hell if you don't rinse it off well. I laid an applicator face up on my work bench with some Ring-go left on it and within about 3 days, fumes from the applicator had rusted every metal tool/part on my bench. I took the applicator out and put it by my water hose on my concrete driveway and the stuff ate away at the cement and discolored the concrete all around the applicator. The stuff is a pink-ish color and I did use it on my drives. Good news is I took some small grit sand paper and cleaned them up.....they look new now. TC
Nuke,
Yeah sometimes the water can cause that. The water in the Colorado river (Havasu) does some weird things to all metal. The IMCO lowers always looked like a rainbow coming out of the water there and anything shiny turned dull instantly. The water is very clean, its just very alkaline. CLR and a scotchbrite pad works good to shine up the raw aluminum, just wear gloves.
