Go Back  Offshoreonly.com > Technical > Electronics
Coil burning out >
Coil burning out
Coil burning out
Old 07-10-2017, 05:09 AM
Triple check you have no bare 12v leads for the ignition. Should be purple wires IIRC in the merc harness. I pinched one once and was chewing thru coils till I found the short.
endeavor1 is offline
Old 07-10-2017, 06:18 AM
great point,,my friend had that same problem.2 gm new style coils burned up.that was a head scratcher.
sutphen 30 is offline
Old 07-10-2017, 08:04 AM
1Bu
I will definitely be checking the harness for a short it sure sounds like a short to me. Thank you for your help. I will let you know what I find
1Bu is offline
Old 07-10-2017, 09:00 AM
Merc harnesses have more than one switched 12v wire. Spend some time with a ohm meter and test light. I bet you can find your problem.
Old 07-12-2017, 10:37 AM
1Bu
I found a plug wire that was pinched in the steering back side of the motor. Could that cause a direct short or just a misfire? It had worn through the insulation on the wire!
1Bu is offline
Old 07-12-2017, 10:43 AM
F-2 Speedy's Avatar
Received 3,048 Likes on 1,357 Posts
the coil is trying to fire that plug through the cap and possibly being sent to ground so I can see this being an issue, and yes misfire fo sho
F-2 Speedy is offline
Old 07-12-2017, 12:07 PM
1Bu
Thank you I've got new distributor coil wires and plugs just scared to death to turn the key and burn something up again! I'll mix up a stiff drink and turn the key!
1Bu is offline
Old 07-12-2017, 01:48 PM
F-2 Speedy's Avatar
make sure you get the firing order correct, you dont need to chasing another problem
Old 07-13-2017, 06:36 AM
1Bu
One at a time
1Bu is offline
Old 07-17-2017, 08:57 PM
1Bu
Thank you everyone for the help! The ignition switch was bad. We are back and running ! Thanks again
1Bu is offline
