Four or Five Blade
#31
Well that is very interesting information. My situation is that my 33 will run 125 at 5,800-5,900 RPM with current 30P Bravo's (non labbed). The motors are 920 HP at 5,700 RPM and put out 890 Ft#'s ! So far draive has been on - Teague's. I do not want drive problems but would like to get up around 130 ish. Like I stated boat gets up on plane easily.
What engines are you running? Hydralic or solid roller cams?
Ther higher X's in the newer boats are definately part of the reson they are so fast...and why 5 and 6 blade props are required. I know someone with a 33 dyatona that runs 6 blade herrings and has a hell of a time getting up on plane..
#32
This brings up a good point, well more of a question really. Is there a certain point (power wise) where 4 blades are impractical? It seems like all of the big power cats and most everything running with sixes have five blades. Do four blades just slip too much to be useable once you pass 700 or so hp?
