Go Back   Offshoreonly.com > Owner's Forum > Eliminator
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-19-2009, 11:36 PM   #1
'96 Eliminator Eagle 250 XP
1996 250 eagle depth guage install
I pulled out the old thru hull transducer today. Instead of being mounted on the flat pad, it was mounted just to the port side of it, or the first part of going up the V of the hull. I would think it should be on the pad. Is that wood that it will not transmit through it? I also found that the old transducer was siliconed down vs being epoxied. Thought that was strange. Any insight on the transducer install on this boat?
cloudmaster_321 is offline   Reply With Quote
Old 05-20-2009, 04:28 PM   #2
"Pure-Play"
28 Daytona
You mean in-hull not thru-hull right?
CheckedOut is offline   Reply With Quote
Sponsored Links
Old 05-20-2009, 05:45 PM   #3
No, thru hull transducer. It epoxies to the inside usually under the motor to the bottom of the hull. It's called a thru hull due to it having to radiate through the hull of the boat.
I ended up calling Eliminator, they said to put it on the flat part of the pad. I'm gonna do some testing with it there before i glue it down and see what i get.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
