Go Back   Offshoreonly.com > Owner's Forum > Eliminator
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-14-2009, 10:04 AM   #1
Eliminator Daytona 33 2005
Cool 2001 Eliminator 36 TEMP problem....????
Recently purchased this boat and it overheats at high speed. Water temp rises way high when I am over 80 MPH on passenger side. Can anyone tell me if the drives have to be parallel to each other or do they have to have ( tow in or tow out ) Pressure drops on each motor depending on what side I turn. Checked lines for obstructions and all sensors with Rinda diagnostic program and found nothing so I figured maybe drive alignment to boat>? Any suggestions would be very appreciated...
Steph
Nuke800 is offline   Reply With Quote
Old 07-14-2009, 11:50 AM   #2
Adrenaline Junkie's Avatar
2007 Daytona 36 Coupe - Twin Vipers
Quote:
Steph
Do you have thru-hull water pickups with strainers on this boat?
Adrenaline Junkie is offline   Reply With Quote
Sponsored Links
Old 07-14-2009, 03:42 PM   #3
No there are not Thru-hull water pickups on this boat. Only pick-ups are the low water pick-ups from the XR drives.
Old 07-14-2009, 08:21 PM   #4
Ptufaro's Avatar
2004 39' MTI
not sure you need them but both of my Eliminator's have had thru hull pick ups. Drives are parallel when turning in and toed in 1/4 when turning out.
Ptufaro is offline   Reply With Quote
Old 07-14-2009, 09:32 PM   #5
Turbojack's Avatar
2003 Eliminator 30' Daytona
Do you have stock Mercury drive or Imco shorties? It just might be that your water pump impellors need to be replaced. I do mine every other year.
Turbojack is offline   Reply With Quote
Old 07-15-2009, 08:12 AM   #6
The drives have IMCO boxes but not the shorties Bit I know that the actual centerline of the prop shaft is about inch and a half higher then the bottom of the boat. I have measured it and wonder if there all in the same position. Both water pump impellors where replaced before it went in the water this year. Ptufaro could you send me a pic of your drive setup? I would like to se where the pick-ups are positioned.
Old 07-15-2009, 10:48 AM   #7
Ptufaro's Avatar
2004 39' MTI
I"ll take some pics of the pick ups later today
Old 07-15-2009, 02:32 PM   #8
Email is nuke800@hotmail.com if anyone has a few pic's of there srive setup. It would be appreciated..
Steph
Old 07-15-2009, 03:46 PM   #9
1996 25' Eliminator Daytona
Put through hull pick-ups on it and you will eliminate any water temp and pressure issues...
x7734x is offline   Reply With Quote
Old 07-15-2009, 06:28 PM   #10
Ptufaro's Avatar
2004 39' MTI
Sorry forgot to take the pics I will be back to the boat this weekend i will try to remember.
I have found one pic that has them but you have to enlarge it.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
