Go Back   Offshoreonly.com > Owner's Forum > Eliminator
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-26-2009, 04:56 PM   #1
28ft eliminator daytona
best prop for 28ft daytona
I was hoping to get some info and opinions on what you guys are running for props. I have a 28ft daytona with about 1100 horsepower and have mercury maximus 5blade 28 pitch props, they are turning in. The boat jumps out of the water and accelerates great but, can barely get over 85. Thanks in advance.
chipwithdip is offline   Reply With Quote
Old 07-26-2009, 11:02 PM   #2
rbtnt's Avatar
2001 28 Eliminator Daytona
Eliminator installed their drives at different heights and this will make a difference on the type of prop that works best. How far up or down from the bottom of the boat are the center of your prop shafts?
I'm running boxes and my shafts are level with bottom. My boat liked Bravos the best or rounded ear Hydromotives.
A friend of mine had the same boat with boxes and his drives were about 1" higher. His boat really like the Hydromotive 5 Blades. His boat was very touchy to get on plane with 34" or 36" Bravo Ones.
www.mtboats.com - Pages of boat related links
rbtnt is offline   Reply With Quote
Sponsored Links
Old 07-27-2009, 02:41 AM   #3
I don't have boxes and I wish I would have measured the shaft height before leaving the boat for the week. I have 502's by the way
Old 07-27-2009, 11:16 AM   #4
Adrenaline Junkie's Avatar
2007 Daytona 36 Coupe - Twin Vipers
Prior to my 36, I had a 2007 28 Daytona with 496 HO's. I had XR drives with 1:36 reduction.
Best prop for me were labbed 32 5 blade maximus with shaved diffuser rings....I would barely bang the rev limiter - jumped out of the hole..cruising speed was great...top end was solid.
...but I was only spitting 425HP aside. If you're blowing more hp than I was, you could certainly spin more wheel than I was...a 28 pitch sounds under-propped to me. I would think you'd be all over the rev limiter with that wheel.
My X-dim was pretty close to level with sponson.
Adrenaline Junkie is offline   Reply With Quote
Old 07-29-2009, 11:05 AM   #5
I had somebody measure my x-dim and he said it was level with the sponson.
Old 07-30-2009, 07:02 PM   #6
No boxes on mine and I'm running 1050 h.p. Maximus 5 blade 32p props work the best for me so far.
grads2112 is offline   Reply With Quote
Old 08-11-2009, 03:35 AM   #7
I got a pair of bravo 1 30pitch from chuckels and tried them out last weekend. I got a little more speed out of them about 3mph, but not quite what I was hoping. Is there anyway to check the gear ratio without breaking down the drives? thanks
Old 08-11-2009, 03:56 AM   #8
02' Eliminator Daytona 30' Open bow
Its usually stamped on the side of the drive.
QWKRN U is offline   Reply With Quote
Old 08-27-2009, 07:12 PM   #9
2009 37 Spectre Diesel CC
29" Hydromotive P5X's worked great for me with twin 496 mags (375hp each) Boat ran 91mph, 1.36 xz drives
pstorti is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
