Go Back   Offshoreonly.com > Owner's Forum > Eliminator
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-27-2009, 10:20 AM   #1
28ft eliminator daytona
eliminator daytona bilge pumps
I bought a 28ft daytona this year and didn't know if it has 2 or 3 bilge pumps. Mine has an aftermarket plate in the center and I can't see if there is one. I am asking because my I pulled it out onto my trailer last week and when I pulled my plugs a lot of water came out of the center hull.
chipwithdip is offline   Reply With Quote
Old 10-27-2009, 03:43 PM   #2
Eliminator 27 ICC
Hard to tell with your individual boat, but how many holes are in back of the boat to discharge out of? (the small billet fittings for the pumps)
merctwofive is offline   Reply With Quote
Sponsored Links
Old 10-27-2009, 06:48 PM   #3
Ptufaro's Avatar
2004 39' MTI
You would have to have some way for the blidge pump to get the water out. More than likely if there is no water line coming out of the center section, than there is no pump.
My Daytona only has pumps in the sponsons none in the center pod. I put a plug in the drain in the engine room, that leads to the ski locker but you need to remue it if it rains and the boat is uncovered.
Your boat will hold water in the ski locker and the cabin if you do not drain the center pod.
Ptufaro is offline   Reply With Quote
Old 10-28-2009, 01:13 AM   #4
MikaylaHunterCig's Avatar
Eliminator Daytona faster puzzycat
My 2006 28 daytona has two pumps, but rarley does it get any water worth mentioning in it.(?)
Check why your boat had so much water in it, unless you were in some real rough stuff i guess.
MikaylaHunterCig is offline   Reply With Quote
Old 10-28-2009, 10:20 PM   #5
rbtnt's Avatar
2001 28 Eliminator Daytona
My 2001 has 3 pumps and my friend's 1999 had 3.
As mentioned before, count the number of discharge holes.
www.mtboats.com - Pages of boat related links
rbtnt is offline   Reply With Quote
Old 10-29-2009, 06:51 PM   #6
02' Eliminator Daytona 30' Open bow
My 02 30 had 2 I added a 3rd just for piece of mind.
QWKRN U is offline   Reply With Quote
Old 11-01-2009, 01:23 AM   #7
My 06 28' has 2 in it.
grads2112 is offline   Reply With Quote
Old 11-02-2009, 10:33 AM   #8
B BOATER's Avatar
2008 Eliminator 33 ICC Daytona
33 has 3 pumps.
B BOATER is offline   Reply With Quote
Old 05-03-2010, 04:54 PM   #9
"Pure-Play"
28 Daytona
My 08 has two, one in each sponson.
CheckedOut is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
