Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 2 of 2
Thread: Dcu2001 + ?
  1. #1
    Join Date
    Aug 2005
    Location
    Charlotte, NC
    Posts
    147
    Dcu2001 + ?
    I have 2 quarts of DCU2001 and would like to know what catalyst I can safely use and mixing ratio. I had DFX7, but now it's a rock! Thanks, G$
  2. #2
    Platinum Member Platinum Member resurrected's Avatar
    My Boats:
    1978 Formula 233 Interceptor
    Join Date
    Jan 2005
    Location
    Owen Sound Ont.
    Posts
    272
    Re: Dcu2001 + ?
    I have some info on this product.
    DCU 2001 is a high solids polyurethane clear
    Urethane hardeners DU 4 (60-70'F)
    DU 5 (60-'85'F)
    DU 6 (85'F and above)
    DFX 7 supercharger
    DT reducers DT 860 (60'-70'F)
    DT 870 (65'-80'F)
    DT 885 (75'-90'F)
    DT 895 (85'F and above)
    Mixing ratios
    medium solids application
    2 parts DCU: 1 part DT:1 part DU
    high solids application
    4 parts DCU : 1 part DT : 2 parts DU
    using DFX 7
    2 parts DCU : 1 part DT : 2 parts DFX 7
    Hope this helps! I have more info if you need it
    I don't know if DU hardener is still available.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
