Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 6 of 6
  1. #1
    Gold Member Gold Member Dave M's Avatar
    My Boats:
    2017 30 Concept, 300 Verados, Superboat Y2k and 24OS (sold)
    Join Date
    Oct 2000
    Location
    LaPlata, MD, USA
    Posts
    5,123
    Fiberglass mat vs. cloth
    What are the pros and cons with mat and cloth?
    I'm building an engine hatch out of either coosa or plywood. I'm glassing in some ribs on the bottom of the hatch.
    Which is stronger?
    I've worked with mat a little, but it looks like working with cloth would be easier and less messy.
  2. #2
    Platinum Member Platinum Member
    My Boats:
    1985 Cigarette 28SS, 2003 Formula 260 SS
    Join Date
    Mar 2001
    Location
    Florida
    Posts
    566
    Re: Fiberglass mat vs. cloth
    I always figured cloth is stronger. I assume you're talking about chop strand mat. I just built race hatches for my 28 Cig using two layers of 6oz. bi axial cloth on top and one layer on the underside. I used epoxy resin and I can jump up and down on them with only a little flex. And I used 1/4 inch birch plywood. Very light and strong. I'll post some pics when I shake this hangover.
  3. #3
    My Boats:
    Join Date
    Oct 2000
    Location
    LaPlata, MD, USA
    Posts
    5,123
    Sounds cool DD! I'd like to see the pics.
    If you are not using gelcoat and a mold what techniques can be used to make the top of the hatch smooth?
    I was planning on having the top of my hatch apolstered so I wasn't too worried about how the fiberglass work looked. But, I may skip the apolstry if I can get a smooth surface on top.
  4. #4
    My Boats:
    Join Date
    Mar 2001
    Location
    Florida
    Posts
    566
    Three coats of self leveling polyurethane paint and more sanding than I care to admit. The epoxy self levels pretty good but the urethane is a challenge. If you mess with it you'll screw it up. If you did all your sanding and then sprayed a few coats that might work but airborne urethane is extremly bad for your central nervous system. I still need to do some sanding and then I'll do a clear coat but if it doesn't turn out like I want it to, I'll upholster it.
  5. #5
    Registered Catagory5's Avatar
    My Boats:
    all of them
    Join Date
    Sep 2001
    Location
    Galloway, NJ
    Posts
    299
    You can use a BPO fairing putty over the epoxy and sand using a long board. Then prime, then paint. The putty will take up any imperfections in the glass and form a good base for the primer and paint. It's also more cost effective and durable then gallons of good paint..
    DD, 3 shots of 6oz over 1/4 inch ply seems a little light to me, depending on the span. You may want to consider another few shots on the bottom if the top is already painted. The flex your talking about, most likely will cause your paint to crack esp since you have it thick enough to fill the print of the fiberglass.
  6. #6
    My Boats:
    Join Date
    Mar 2001
    Location
    Florida
    Posts
    566
    Cat 5,
    I agree with you about it being light but that was the way it was designed. You'll see when I post the pics. There is not much of a span. Also the flex is minimal in the weakest spot with 190 lbs jumping on it. I appriciate the input.
Similar Threads
  1. MAT Sensor question
    By rangerrick63 in forum General Q & A
    Last Post: 08-06-2007, 07:40 AM
  2. This guys got to be cut from OPA cloth...Augie ...Smitty?
    By throttleup in forum General Racing Discussion
    Last Post: 03-07-2007, 04:26 PM
  3. Stitched mat with chopped mat
    By jdub in forum Fiberglass and Paint
    Last Post: 02-09-2007, 07:54 AM
  4. Fibreglass cloth
    By TopSpin80 in forum General Boating Discussion
    Last Post: 01-30-2007, 05:16 PM
  5. Fiberglass Mat Question
    By Shah Mat in forum Fiberglass and Paint
    Last Post: 05-22-2006, 10:50 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2017 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
